Discussion topic: Broken remote control
This message was authored by: TerryW1955
Where can I get a replacement Sky Q remote control
Re: Broken remote control
@TerryW1955
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
This message was authored by: Andrews4
How can I get a replacement remote control
@Andrews4
You don't appear to have read my post immediately above yours.
Hi @Andrews4   You look at the post above yours.
