Discussion topic: Broken remote control android phone
This message was authored by: Julie171
Help remote is broken ...yes I've tried 3 different batteries that are working in TV remot ! Have an android phone not an apple so how can we change channels without remote ?!
Re: Broken remote control android phone
Hi @Julie171
Try completly resetting your Bluetooth remote.
With the Q box on with green led
If the Q box is not on try pressing the Standby button (Amber led) on the front of the Q box.  Then reset the remotes as above
hi @Julie171
Unfortunately, as you may have found out, the Virtual remote on SKY go is still only available on apple devices.
Please may I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
If that doesn't work there is a possibility that there is an Android 3rd party app that might work but I don't know for sure.
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Avatar for Julie171
Level 0 icon
Thank you  that didn't work but made us know remote was still active turned box off at plug and seems OK now !
This message was authored by: mappion
Hi @Julie171
Glad you have got it all working now.
As an emergency backup in future, there is an app on android called 'Sky Q Free Remote' I've used in the past that does work. To save getting it mixed up with others it appears as a square Blue app with a large white 'Q' on it. There are probably other android apps around as well that probably work, but I havn't needed to try them.
