Discussion topic: Broadband n sky q
This message was authored by: Sooty0209
Broadband n sky q
Broadband keeps dropping out on sky q had engineer out changed box everything worked for couple of weeks now for the last 3 evening it drops out for few minutes it's getting very annoying
Re: Broadband n sky q
Hi @Sooty0209
Assume you have tried a Network reset on your Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
If the issue continues you could ask Sky for a Q WiFi booster to aid connectivity.
