Discussion topic: Broadband connection
Message posted on 13 Feb 2026 10:07 AM
After our electricity was turned off for work being done we gave list our broadband connection to the tv. We have sky a Abdul sky broadband. We gave tried connection using the password but it keeps saying the password is wrong. We gave checked and double checked, all upper and lower case correct. Advice?
Message posted on 13 Feb 2026 10:47 AM
Re: Broadband connection
Hi @Tt32
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky fibre Broadband with the new white Sky Max router, then you need into connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky or Sky Max router) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
White or black router?
