Discussion topic: Boxes in bedrooms don't work
Message posted on 05 Feb 2024 04:16 PM
Message posted on 05 Feb 2024 04:17 PM - last edited: 05 Feb 2024 04:19 PM
Re: Boxes in bedrooms don't work
@Becky1814 wrote:
Both our boxes in our bedroom don't work. We've tried everything.
Hi @Becky1814
Reboot the mini as above. Start with the mini nearest to the main Q box.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.
