Discussion topic: Box upstairs wont connect to sky q box
Message posted on 21 Jul 2024 03:09 PM
My multi room box upstairs will not connect to my sky q box
Message posted on 21 Jul 2024 03:17 PM
Re: Box upstairs wont connect to sky q box
Hi @Sineadvine
Reboot the mini as above.
