3
This discussion topic has been answered Discussion topic: Box swap
This message was authored by: 20Frankie12
Box swap
Is it possible to swap a sky q box for an internet based system
This message was authored by: nigea99 Answer
Re: Box swap
hi @20Frankie12
SKY's bradband delevered sstem is called SKY Stream (or Glass if you want to buy a physical TV)
You should be able to switch from SKY Q mid contract but you will need to call SKY to do this
Note Stream is different in severel ways (e.g. use of playlists rather than physical recordings) - so do research
Re: Box swap
hi @20Frankie12
Re: Box swap
Yes, but you'd have to call Sky and negotiate a deal.
Re: Box swap
Hi @20Frankie12   If you go to sky.com, then TV and select Stream it should give you an idea of the price to change. The last time I looked they wanted £20 more a month for the same Sky Q package.
