Discussion topic: Box overheating
Message posted on 13 Jun 2025 07:17 AM
Box overheating
Box overheating
being switched off at mains each night due to concern over fire risk
can you please advise
thank you
Message posted on 13 Jun 2025 07:22 AM - last edited: 13 Jun 2025 07:24 AM
Re: Box overheating
Is it in a well ventilated position? They are designed to get warm but you should be able to rest the palm of your hand down on the top. If you can't then contact Sky to get it swapped. If you do need a new box remember to remove the viewing card from the faulty box.
Message posted on 13 Jun 2025 07:25 AM
Re: Box overheating
Yes well ventilated
thank you I will request a replacement
Message posted on 13 Jun 2025 02:29 PM
Re: Box overheating
Hi @Sb71
I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Scott
Community Moderator
Message posted on 13 Jun 2025 02:32 PM
Re: Box overheating
Hi there! Thank you for escalating this. We have sent an invite to @Sb71;
