Discussion topic: Box not recording
Message posted on 26 Feb 2024 10:07 AM
Box not recording
Sky Q not recording
Message posted on 26 Feb 2024 10:12 AM
Re: Box not recording
@Jamie3331 wrote:
Sky Q not recording
Hi @Jamie3331
If a reboot doesn't help you may have a hard drive issue.
Failing this
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Ordering a new Q box usually means a doorstep swap.
@Jamie3331
You’re not talking to Sky Customer Services on here. This is a customer based forum where customers try to help other customers.
We'll need more information in order to advise. What is happening when you try to record? What are you trying to record and in what format?
