Discussion topic: Box not recording or deleting
This message was authored by: JoanneT59
Nor won't delete or record
Re: Box not recording or deleting
@JoanneT59
Not a lot to go on there…
Have you tried rebooting  the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
