Discussion topic: Box locked up every morning
Message posted on 26 Sep 2023 08:23 PM
I just got a new 2TB box (32B108) after my original Q box's hard drive died. I've had it a week now and every morning it has its fan loudly whirring and the orange standby light on.
It won't come out of standby with the remote or the buttons on the front of the box and I have to switch it off at the mains and power on again.
Message posted on 26 Sep 2023 08:25 PM
Re: Box locked up every morning
Hi @sk00v
Message posted on 26 Sep 2023 08:33 PM
Thanks @oldfella I should've added, I tried all the reset options in that menu and powering off the box and holding the standby button until it flashes. Also moved the box to a 'cooler' location to see that helped.
I tried changing the standby mode to 'eco', 'active' and 'none' and that made no difference either.
It works fine all day, happily on standby all day whilst we're at work/school and fine all evening. Then same again every morning.
Message posted on 26 Sep 2023 08:36 PM
Hi @sk00v
Looks like you need to contact Sky for an Engineer then @sk00v
Message posted on 26 Sep 2023 08:44 PM
@oldfella yes, I feared as much. Just frustrating with it being a new box and trying to arrange a convenient time.
Will give them a call tomorrow.
thanks.
Message posted on 26 Sep 2023 08:51 PM
I had this with a brand new v3 box. Had to get another which was more difficult than you might think. I think because the system hadn't fully accepted it had my old one back or something.
Message posted on 26 Nov 2023 09:34 AM
My box is quite a few years old and worked fine for a long time but for the last year has been doing the same most mornings.
I would say 2 in every 3 days requires power cycling first thing.
Phoned support and done all they suggest, change Eco mode etc. but nothing fixes it.
It's clearly a firmware bug as it gets in a loop at a certain time in the early hours either when checking for an update or when it gets some signal to do so from Sky and has no watchdog or ability to do a self reset because otherwise if it were a hardware issue, a manual reset wouldn't temporarily resolve the problem.
They believe hard drive is faulty but being an electronics designer, I can tell the difference between a fast spinning cooling fan and a hard drive spinning at 5400 or 7200.
Seems the only fix will be a new box but there is too much recorded that I will lose and never get opportunity to watch and catch up as my new job means I'm away more.
