This discussion topic has been answered Discussion topic: Both Sky q mini boxes stopped working and won’t reconnect
Message posted on 21 Aug 2024 01:23 PM
Both mini boxes upstairs have stopped working and won't reconnect to the main box
Message posted on 21 Aug 2024 01:42 PM
Hi @Mark6441
Have you correctly completed a Network reset on the minis? Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the minis and you will need to contact Sky directly.
Message posted on 21 Aug 2024 01:31 PM
Re: Both Sky q mini boxes stopped working and won’t reconnect
Sorry should add, broadband working fine, I have already restarted the router the main sky q and both mini boxes
Hi @Mark6441
Message posted on 21 Aug 2024 01:56 PM
Sorry all, fixed by doing a full reset on the mini box and re-paired with the main box again
