Discussion topic: Bluetooth Remote
This message was authored by: Matt28
Bluetooth Remote
Can someone explain how to make my remote work via Bluetooth and not IR please?
Currently got the tv in front of the sky Q box while I decorate ready for the new tv and QUHD but it's a pain to control at the moment.
Re: Bluetooth Remote
Hi @Matt28Provided it is a Bluetooth remote (all Bluetooth remotes have a Microphone button for Voice control)
Note that Bluetooth control is only for the Q box.  All TV control is always by infrared.
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Depends on how old your remote is - it may not have BT anyway.
But holding 4&6 will switch modes.
EDIT: Or use the reset procedure as above...
"Note that Bluetooth control is only for the Q box."
Pretty sure my minis work over bluetooth. One of them is mounted behind a TV.
Mini is a Q box @Chodley
