1
This discussion topic has been answered Discussion topic: Blue screen
This message was authored by: nairekrap
Blue screen
Does anyone else have a problem with reading g the text on the blue screen .?
This message was authored by: lettice Answer
Re: Blue screen
You can also increase the contrast on your Sky Q box to make things easier:
  1. Press Home on your Sky Q remote and select Settings.
  2. Select Accessibility, then High contrast and change the setting from Off to On.
  3. Press Dismiss to return to live TV.
More on similar accessibility options here;
https://www.sky.com/help/home/sky-tv/sky-tv-q/setting-up-sky-q/setting-up-accessibility/setting-up-q...
Re: Blue screen
