Discussion topic: Blue screen technical fault when playing recordings
This message was authored by: gary12366446
I have an issue when playing recordings where they will play for a bit then a blue screen shows up and says: there is a technical fault with this channel, please try again later.
I have reset the box, I have also turn off at the mains and turned back on but problem still remains. I've seen online that to try resetting the hard drive but I don't really want to lose my recordings if possible, so any help with that?
also, when I use the YouTube app on the box and I'm watching something it will stop playing the video and show 'loading', and I have to rewind the video to get it to play again. Any help with one too?
Re: Blue screen technical fault when playing recordings
Hard drive could well be on the way out so I think you might not have a choice on losing the recordings anyway.
