This discussion topic has been answered Discussion topic: Blue screen on multiroom
Message posted on 21 Jun 2023 12:31 PM
Sky multiroom goes to blue screen and then goes back on but it does it regularly it's been doing it a few weeks
Message posted on 21 Jun 2023 12:41 PM - last edited: 21 Jun 2023 12:41 PM
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini as the Network reset will start the mini WPS automatically ).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. Make sure you press the WPS button on the Sky router and not the reset button.
Message posted on 23 Jun 2023 07:44 AM
Re: Blue screen on multiroom
Just done it seems to be ok now many thanks
Message posted on 27 Aug 2024 07:51 PM
I have same issue I have rebooted and tested the wifi still not fixing the issue any other ideas
