Discussion topic: Blue light not illuminating on Sky Q box
Message posted on 08 Mar 2023 04:23 PM
I've just had Sky Q installed.
I was under the impression that the blue Q on the front of the box lights up when I pause a programme and remains on when I continue watching ... until I change channel, or fast forward in order to 'catch up.'
It isn't.
Is this correct?
Message posted on 08 Mar 2023 04:27 PM
Re: Blue light not illuminating on Sky Q box
It isn't.
Is this correct?
Hi @Dicko3
Yes it should be on during pause or paused playback.
First try rebooting your Q box
If this doesn't fix it
Message posted on 09 Mar 2023 10:11 AM
Tried both suggestions - no joy I'm afraid.
