Discussion topic: Blue colour picture when using sky
This message was authored by: LouiseMc16
When watching tv using sky there is a blue colouring to my screen but when I use Apps or the normal freeview on the tv the colouring is perfect. I have checked and changed HDMI leads and no difference. Can anyone tell me if this is a fault in the sky box?
Re: Blue colour picture when using sky
Hi @LouiseMc16
If rebooting your Q box doesn't fix it it is likely to be a TV set setting you need to change for the HDMI input used with Sky Q.
