Discussion topic: My sky Q will not connect to my internet
This message was authored by: Natalie741
My sky Q box will not connect to my internet.
we have followed all the instructions on the tv & reset the router & it is still not working?
Please help ASAP
Re: My sky Q will not connect to my internet
Please help ASAP
Hi @Natalie741
