4
This discussion topic has been answered Discussion topic: Blank screen
This message was authored by: GMoran
Blank screen
My sky is on and I can access the menu/ tv guide/ app page etc but when I select a channel it's just black with no picture or sound. It's not a HMDI thing or anything as the sky menu etc is working we just can't seem to get any channels working.
Re: Blank screen
Hi @GMoran
Re: Blank screen
Hi @GMoran   Have you tried a power reboot of both your TV and Sky Q box?
Re: Blank screen
Hi @GMoran
Avatar for GMoran
Level 0 icon
Re: Blank screen
Yes I have tried this. Thank you
This message was authored by: Wallacesstreet1
Re: Blank screen
I followed everything as per instructions ie using the secret menu and I still have a blank screen , what next ?
