Discussion topic: Black screen/planner rebuild?
Message posted on 14 Jul 2024 05:15 PM
How do I do a planner rebuild?
on record, rewind, try to get back to where I was watching, black screen. Pul plug on box. Wait, reboot but still black screen?
Message posted on 14 Jul 2024 05:43 PM
Re: Black screen/planner rebuild?
A planner is a Sky+ term. Can you confirm you have Sky Q where you've posted.
Message posted on 14 Jul 2024 05:51 PM
Yes, a sky Q box.
just read it was a sky+ feature.
Message posted on 14 Jul 2024 05:59 PM
So if you've currently lost the epg reboot your router first then try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Message posted on 14 Jul 2024 06:07 PM
Thanks Daniel.
switched off router and Q box. Left for ten mins. Just need to await next episode that I need to rewind or restart a program that I'm watching.
it does seem to be more on recorded programs at late afternoon,maybe it's because I'm just settling to watch tv at ghat time of day. Thanks for you advice.
