Discussion topic: Black screen no Q light
Message posted on 22 Apr 2023 09:10 PM
Sky TV not working only showing black screen. Green light is on and red record is on and no blue Q light. Tried rebooting but issue still the same. Any other ideas on how to fix?
Message posted on 22 Apr 2023 09:23 PM
Re: Black screen no Q light
@Samann86 wrote:Sky TV not working only showing black screen. Green light is on and red record is on and no blue Q light. Tried rebooting but issue still the same. Any other ideas on how to fix?
This may be the problem - you need to reset your picture resolution. If you're stuck on a plain black screen, it could means you've selected a picture resolution that your TV doesn't support. Press Home, 1,0,8,0, Home, on your Sky Q remote to reset your picture resolution.
Message posted on 22 Apr 2023 09:33 PM
This has not worked for me. Still same issue on going.
Message posted on 23 Apr 2023 09:47 AM
@Samann86 wrote:This has not worked for me. Still same issue on going.
Try these pointers - Sky Help | Sky.com
