Discussion topic: Best WiFi booster to use with bt internet for my Q box
Message posted on 15 Jun 2025 09:07 AM
My sky Q boxes keep losing connection with my bt WiFi booster and have to be reset on a regular basis which other WiFi boosters can people recommend to use please
Message posted on 15 Jun 2025 09:17 AM
Re: Best WiFi booster to use with bt internet for my Q box
Q Mini boxes only works with WiFi from Sky-branded booster hardware.
A potential workaround is to connect Minis to non-Sky nodes using ethernet cable.
Message posted on 15 Jun 2025 09:26 AM
Thanks can I use a sky wifi booster with a bt hud bo you know please
Message posted on 15 Jun 2025 01:28 PM
Hi @Johnyb
You can use a Sky Q WiFi booster to help connect mini boxes. In this case the booster is connected to the main Q box by WPS and then the mini connects to the booster by WPS. Booster located between main Q box and minis.
Also you could connect a Sky Q booster to your BT router by Ethernet. In this case you should be able to connect your main Q box to the booster by WPS.
