Discussion topic: My sky dish has been knocked can I realign it myself?
Message posted on 30 Jun 2023 04:11 PM
Scaffolders have moved my dish out if place
Message posted on 30 Jun 2023 04:19 PM
Re: My sky dish has been knocked can I realign it myself?
Probably not. But you can try and see if you're 'lucky'.
(Alignment is performed with a meter to ensure the signal is correct)
Message posted on 30 Jun 2023 04:20 PM - last edited: 30 Jun 2023 04:28 PM
The fine adjustment to elevation, azimuth and skew is likely to be impossible without access to a Q-compatible signal meter. If above ground level there's obviously also some element of risk involved, so really not advisable.
Note that the cheap meters available online are typically compatible with Sky+ / Freesat LNBs but not Sky Q
