Discussion topic: Berry
This message was authored by: Mary+kennedy
Berry
My sky q box will not switch on red light flasing
Re: Berry
Hi @Mary+kennedy
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Avatar for Mary+kennedy
Mary Berry
Extra sky a box will not receive sky
Re: Mary Berry
Extra sky q box will not receive sky
Re: Mary Berry
@Mary+kennedy
What error message if any are you seeing on your mini box?
Have you tried a reboot, ie;
a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
▪️I AM NOT A SKY EMPLOYEE ▪️
