Discussion topic: Bbc message
This message was authored by: Lensgirl123
Bbc message
Hi I now have a message on my BBC one channel about the upgrade, however I have a sky Q box and pay for HD?
Re: Bbc message
The message appears on the SD version of BBC1, not BBC1 HD.
Avatar for Lensgirl123
Re: Bbc message
Hi Yes and it appears my channel 101 is an SD version but I have all the upgrades for HD?
Re: Bbc message
@Lensgirl123
If you are referring to the message regarding the end of SD channel broadcast and the 'free' upgrade to A, that is being carried on all BBC SD channels, which suggests you were either watching such a channel live or had inadvertently recorded from one.
Re: Bbc message
Hi Yes, I am watching Channel 101. But how can my sky version of BBC 1 be an SD version when I have Sky Q and the HD package?
Re: Bbc message
@Lensgirl123
It might be worth rebooting your main Sky Q box and seeing if the HD channel reverts back to 101.
~ press the 🏠 button
Re: Bbc message
That worked, thank you!
