Discussion topic: Bbc message
Message posted on 26 Nov 2023 08:11 AM
Bbc message
Message posted on 26 Nov 2023 08:13 AM
Re: Bbc message
The message appears on the SD version of BBC1, not BBC1 HD.
Message posted on 26 Nov 2023 08:15 AM
Re: Bbc message
Re: Bbc message
If you are referring to the message regarding the end of SD channel broadcast and the 'free' upgrade to A, that is being carried on all BBC SD channels, which suggests you were either watching such a channel live or had inadvertently recorded from one.
Message posted on 26 Nov 2023 08:47 AM
Re: Bbc message
Message posted on 26 Nov 2023 08:51 AM
Re: Bbc message
It might be worth rebooting your main Sky Q box and seeing if the HD channel reverts back to 101.
~ press the 🏠 button
Message posted on 26 Nov 2023 09:06 AM
Re: Bbc message
That worked, thank you!
