Discussion topic: Bbc iplayer buffering and freezing
Message posted on 29 Nov 2023 04:52 PM
Hi does anyone know why BBC iplayer is buffering and freezing internmitently when its played though my skyQ is it a inown issue? all other apps are fine and my connection is fine i have fibre to the prem and having no problems at all. its so annoying having to switch apps.
Message posted on 27 Jan 2024 11:25 AM
Re: Bbc iplayer buffering and freezing
I have the same problem did you get an answer?
Message posted on 27 Jan 2024 11:33 AM
@94 Not having any issues here
Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 27 Jan 2024 12:16 PM
Yes I have tried this (twice) but the problem is still there.
Message posted on 30 Jan 2024 09:19 PM
The problem is clearly iplayer and I wish people would stop saying the same old reboot this or clear cache etc. You go on Google and its the same issue evrrywhere for so many, everything else is fine Internet speed is good but iplayer just keeps stuttering.
Message posted on 04 Jun 2025 08:45 PM
It's still the same in June 2025! IPlayer plays well on other devices but not via Sky Q, why is that?
Message posted on 14 Jul 2025 10:36 PM
I am going bananas trying to watch I player
it takes ten times longer to watch a half. Hour programme . I pay a fortune for Sky and my internet is Bt also a fortune and I do all the recommended things to try and fix it
very frustrating !!
Message posted on 18 Mar 2026 08:28 AM
It is still the same as of March 2026. I can't believe that there has been no reasonable response to this issue. I have the maximum bandwidth, sky fibre internet and my router is right next to my qbox, both a metre away from the tv with a direct line of sight.
There must be an issue at Sky's end. I just can't watch anything on iPlayer as the buffering is so bad
