2
This discussion topic has been answered Discussion topic: BT new digital system
This message was authored by: Pasty
I'm confused, I have a sky q box and I have received a card from BT saying they will be sending me a new router for the new switchover,  what do I do I'm confused.
Re: BT new digital system
Hi @Pasty
This is nothing to do with your Q box.
I suspect you are getting a new router from BT to enable you to switch your phone service over to VOIP (voice over internet protocol).
You will however have to reconnect your Q box to connect to the new router.
Hi @Pasty
By the way your existing BT router will continue to work for a long time yet so there's little point swapping it with all the wifi device fuss that is likely to entail.
