1
This discussion topic has been answered Discussion topic: BT hub connection
This message was authored by: Doe2
BT hub connection
I have changed my BT Hub and the Q box is connected via ethernet, its all working and the mini box is too
However in the settings it shows the old hub not the new one ?
This message was authored by: MightyQuinn Answer
Re: BT hub connection
Hi @Doe2   If it works you can safely ignore that. That display setting has never worked properly. My box once showed a router I had disconnected three years ago!
Answered - Go to Answer
