Discussion topic: BBC Iplayer
This message was authored by: jmam
BBC Iplayer
When l try anf login to iplay under my user name l get the message 'this can sometimes take up to 30 seconds, depending on your network connection'
This is on all my sky boxs, l have down a power reset and still the same.
This message was authored by: Max1943
Re: BBC Iplayer
I have the exact same problem.
ive been in discussion with the tech team for over a week with no reply since Sunday so nothing to help at this point.
i have a Firestick with which I access iPlayer but that's not ideal or a solution to the problem.
