Discussion topic: BBC 1 pixelating
Message posted on 21 Mar 2023 08:21 PM
BBC 1 pixelating
We have just returned from a long holiday, everything on my sky Q is working perfectly except BBC1 which is so pixelated we can't watch it. We've done the usual checks signal, WiFi etc and we've updated the box, any ideas would be gratefully accepted.
Message posted on 24 Mar 2023 06:06 PM
Re: BBC 1 pixelating
Same here in Leicester, it's been like it for weeks, SKY simply do not care, I have to use the regional bbc channels on the high 900s
Message posted on 24 Mar 2023 06:22 PM
In both cases I would call up and insist on an engineer visit as it is likely to be a dish issue (even if no other channels are affected).
Message posted on 24 Mar 2023 07:11 PM
Hi I did phone sky and they didvthebusual checksvetc then said they would send an engineer, he came and our cable toothed aerial was damaged, they replaced the wire and happy to say its working perfectly now.
Message posted on 09 May 2023 04:07 PM
We had this same problem, it was very intermittent at first but as gradually got worse until a few days ago became unwatchable. We could still watch BBC1 via terrestrial Tv so we knew the Tv was ok.
The sky engineer has just left and all is well now.
Hopefully the following is useful to anyone else having the same issues.
FYI. Live TV is currently transmitted via your dish and cables. Catch up and streaming services come via your broadband.
In our case the engineer removed the cables from the back of the box and he could immediately see that one of the copper ends was corroded and one of the box connectors was corroded too.
So water/ moisture has got into the cable and through gravity eventually found it's way into the house and sky box.
So the cables need replacing. If they do this for you ensure the new cables at the dish end are secured to the dish bracket and not just left hanging free as they were with ours. Also don't let them just cut off an inch or two from the cable ends and put new connectors on, or the problem will sooner or later return. Make sure they replace the whole cables, and given there could be internal corrosion I'd push for a new box too even if it looks ok, after all moisture has got into your box through one or both of those connectors.
Hope this helps.
Message posted on 18 Jul 2023 10:34 PM
Same here I'm leicester too, thanks for advice, I'm going to phone sky tomorrow see what they say, had lots of issues with the broadband and phone line with water or damp getting in somewhere
