Discussion topic: BBC 1 loses signal
Message posted on 17 Aug 2025 10:36 PM
BBC 1 loses signal
BBC 1 signal is bad during the day. By the evening it is unwatchable or signal loss completely. All other Channels are fine. The signal quality is always at 90 and signal strength 50. It has been like this for the past few weeks. Is there a reason for this. There is nothing in the way of the satelite but if there was I would expect other channels to be affected but work perfectly
Message posted on 18 Aug 2025 05:42 AM
Re: BBC 1 loses signal
@Adey8
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 18 Aug 2025 07:17 AM
Signal strength and quality are not tested on the frequency of the channel you are on so it coud be bbc1 (and anything else on the same multiplexor frequency) is affected more than the test channel they use.
and 50 isn't great. Suspect your dish needs aligning.
