6
This discussion topic has been answered Discussion topic: Av cut my ethernet cable
This message was authored by: donoghuedarren1
Av cut my ethernet cable going to my sumer house
Re: Av cut my ethernet cable
Looks like you may need to replace it @donoghuedarren1
Avatar for donoghuedarren1
Level 0 icon
I need an engineer
Level 0 icon
Trying to get an engineer what an nightmare it is Trying to get some 1
hi @donoghuedarren1
If it is an ethernet cable then I am not too sure SKY will replace that for you
@donoghuedarren1
I doubt Sky would have installed such a cable in the first place: in rare cases they do so within a property (where all attempts at Q over WiFi have failed), but not for an external location.
You'd typically need a network installer, knowledgeable electrician or competent handyperson to do such work if you don't wish to try DIY.
This message was authored by: Dazzasky
I need an engineer
No, you just need to buy a new cable @donoghuedarren1
