Discussion topic: Auto reconnect
Message posted on 18 Aug 2025 03:25 PM
Auto reconnect
Does the skyq box automatically reconnect to the internet like a mobile phone if the signal is lost?
Message posted on 18 Aug 2025 03:41 PM
Re: Auto reconnect
@ricsv8 yes it should do mine does
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 18 Aug 2025 04:28 PM
Re: Auto reconnect
Yes, mine does usually but didn't last night. Do you know if there is a minimum signal strength below which it doesn't automatically reconnect? I'm trying to rule out the router being the cause
Message posted on 18 Aug 2025 04:31 PM
Re: Auto reconnect
@ricsv8 Afraid I have no idea whether there is a minimum signal strength or not sorry
