Discussion topic: Atlantic
This message was authored by: Sam2009
Atlantic
Hi all, I'm rewatching GOT and I can access the whole thing via the app but when I go to watch it on the tv it's asking me to subscribe. Why is this?
Re: Atlantic
hi @Sam2009
Is it possible you are trying to watch the UHD version without the UHD add on, or  the HD version without the HD add on ?
If you don't have the UHD or HD add on, best to change the default in :
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
Avatar for Sam2009
Re: Atlantic
Ooooh, great advice. Thank you. Have a lovely Christmas xxx
Avatar for Sam2009
Re: Atlantic
Hi again, it still hasn't worked. Moved to HD, managed to ask it to download and now it's saying to watch the download I have to upgrade. Can anyone help?
Re: Atlantic
Hi @Sam2009
You haven't specified if you have the Sky Q Monthly add on subscription for HD.
If you haven't you need to select SD in the settings.
Home - Settings - Preferences - On demand download format
Set to SD
