Discussion topic: Atkins
Message posted on 13 Jun 2024 05:01 PM
Atkins
The picture is breaking up and the sound goes we cannot watch it like this.
Message posted on 13 Jun 2024 05:36 PM
Re: Atkins
@Averil+Atkins wrote:The picture is breaking up and the sound goes we cannot watch it like this.
Your dish probably needs re-aligning. Call Sky and book an engineer.
Message posted on 13 Jun 2024 05:39 PM
Re: Atkins
