Discussion topic: Aspect ratio sky q
This message was authored by: Royf59
Aspect ratio sky q
I've tried without success to find a setting on sky q where I can change the ratio so I'm not watching some movies through a letterbox. TV company Sony say the setting should be on the SKY Q and not TV.
Re: Aspect ratio sky q
Sony is incorrect.
Avatar for Royf59
My old TV LG packed up so bought a Sony just last week. It does have a setting to change screen setting but it says function not available.
Hi @Royf59   What resolution have you set on the Sky Q box? You will probably find that you can only change the aspect ratio on the Sony by choosing 1080l/p on the Sky Q box. Sony lied to you, you can only alter the aspect ratio on a TV. I personally haven't played with aspect ratios since the 1990s. I prefer to watch films etc. the way the director wanted us to view it.
Avatar for Royf59
Thanks. I'll try that.
If you're seeing black lines on a film that's probably how it's intended to be seen. Many are shot in a format wider than a widescreen TV, so by getting rid of the black bars you'll be seeing a zoomed in, distorted image just to fill the screen.
A lot of movies are 16:9 these days so should fit the screen but some are still shot in wider ARs. The black borders in that case are part of the 4k image and I suspect most TVs won't let you push the sides off / zoom in these days.
@Royf59
As @MightyQuinn says you won't be able to change any aspect ratio if the resolution is set to 2160p as that is a fixed ratio of 16:9
Most Tvs will allow you to play with aspect ratio in HD mode but note the actual signal from the HD channels is usually  still 16:9  - the broadcaster adds the black bars to older 4:3 SD programmes to maintain the correct aspect ratio.
The problem of course is that 4:3 signals don't fit 16:9 TVs so there a few choices available - the one used is to maintain orginal screen ratio and add the bars either side to fill the 16:9 screen.
The others that the TV may allow is to stretch the image sideways to fill the screen - this can be a uniform stretch which can be very noticeable or a more gradual stretch that leaves the centre fairly untouched but streches the edges even more .
An alternative is to zoom  where the TV will fill the screen sideways but end up loosing the top & bottom of the image
We used to have the flip to this in the days of 4:3 TVs and films produced in 16:9 or wider -in those days the braodcasters often used a thing called Pan & scan where they zoomed the image and lost part of the image at the sides but would 'pan' to make sure the main action was included (e.g. sometimes the position chosen would be at one side rather than the middle). Again as an alternative they would add black bars top  & bottom to allow all the image to be seen. This letterboxing was probably more used in Europe than here.
Personally I have always preferred to see the image in original ratio format with black bars added when needed.
