Discussion topic: Apps
Message posted on 24 Jul 2024 09:31 PM
Apps
Hello I cannot access any of my apps on one of my Q box how do I fix it ?
Message posted on 24 Jul 2024 09:51 PM
Re: Apps
@Big+smile Have you tried rebooting your Q box ie
if that doesnt work
you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
