5
This discussion topic has been answered Discussion topic: Apps
This message was authored by: NicholasK9
Apps
Hi my apps have disappeared from my app bit Disney Netflix we'll all barring peacock which I don't even no what that one is can any one help I have tried the settings 0 0 1 and a reset but still nothing
thank you
This message was authored by: Quoman7 Answer
Re: Apps
@NicholasK9 Have you tried using voice control to find a specific app?
Re: Apps
thank you
Hi @NicholasK9 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Avatar for NicholasK9
Re: Apps
Hi I've done that about 3 times still nothing 😩 I watch Disney all the time ans it's just disappeared x
Re: Apps
Re: Apps
I have just tried that and has found it thanks so much I didn't think of that 😃
This message was authored by: tinatony1
Re: Apps
What actually worked??
