5
This discussion topic has been answered Discussion topic: Apps wont refresh
This message was authored by: KayMcV
Apps wont refresh
Hi
None of my apps will open - I've tried a software update etc and got stuck on the engineer refresh option.  I get an error message saying there is a problem refreshing apps.  Any ideas?
Re: Apps wont refresh
@KayMcV wrote:
Hi
Hi @KayMcV
First Reboot the Q box.
Then try refreshing the Apps again in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
@KayMcV wrote:
Hi
Hi @KayMcV
Select Apps 
Avatar for KayMcV
Thanks @oldfella, apps are now refreshing.  Fingers crossed!
This message was authored by: Json71
Hi there, I've had the same problem on a second sky mini box. The main sky Q box and first mini box are fine but the second box has no apps. I've followed the instructions above but I get the same error message every time. Any ideas anyone?
This message was authored by: MitchellHancox
My5 app won't refresh on my sky glass tv
This message was authored by: Jayzee08
Hi, I tried this fix today and it's not letting me access the secret menu to do this. Has the location changed? Any help appreciated, thanks
