5
Discussion topic: Apps wont refresh
This message was authored by KayMcV This message was authored by: KayMcV
Apps wont refresh
Hi
None of my apps will open - I've tried a software update etc and got stuck on the engineer refresh option.  I get an error message saying there is a problem refreshing apps.  Any ideas?
This message was authored by oldfella This message was authored by: oldfella Answer
Re: Apps wont refresh
@KayMcV wrote:
Hi
Hi @KayMcV
First Reboot the Q box.
Then try refreshing the Apps again in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
