Discussion topic: Apps won’t load on multiroom
Message posted on 22 Dec 2024 08:37 AM
When I try to access Disney and Paramount apps it takes me to home page to set up account, but it works on main box, I have tried a reset and tried the reset your Apps still nothing , need help please
Message posted on 22 Dec 2024 08:40 AM
Re: Apps won’t load on multiroom
Hi @summersean Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with any Mini boxes?
Message posted on 22 Dec 2024 08:45 AM
You have to login separately on the mini. It doesn't inherit the login from the main box.
