Discussion topic: Apps not working
Message posted on 26 Oct 2025 09:48 AM
Apps not working
My mini sky q box will not work and when I try to connect to apps it says I have no internet. My Netflix is showing in another language
Message posted on 26 Oct 2025 11:58 AM
Re: Apps not working
@Son11 that seems to beto desperate problems the netflix problem sounds as though your Netflix account has been hacked. In these situations you will need to contact Netflix who will be able to reset your account.
You can contact Netflix on the link below
https://help.netflix.com/en/contactus
The non connection problem
Have you tried rebooting your main Q box ie
Then
Reboot the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
