This discussion topic has been answered Discussion topic: Apps not working
Message posted on 30 Mar 2024 09:42 AM
Watching a programme on ITVX yesterday. Screen froze then went blank. Now we can't access any apps (Netflix etc). Have rebooted SkyQ box to no avail. All other programmes are working ....help?
Message posted on 30 Mar 2024 10:07 AM
Hi @Sue+LM
Have you tried refreshing the Apps in the Hidden menu.
Select Apps
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
Hi @Sue+LM
Select Apps
Message posted on 30 Mar 2024 10:15 AM
Re: Apps not working
@oldfella @Just tried this and it comes up with 'there was a problem refreshing your apps ' 🤷🏼♀️
Message posted on 30 Mar 2024 10:16 AM
Looks like your Q box does not have internet connection @Sue+LM
Try resetting the connection.
Message posted on 30 Mar 2024 10:30 AM
@oldfella Thank you so much! All up and running.....5* response!
Message posted on 25 Jan 2025 10:39 PM
Hi I have the same problem, have sky max router, have switched off at mains etc, still saying no network connection please help, have lost all apps, Netflix, you tube etc
