Discussion topic: Apps keep restarting
This message was authored by: danhollywood
Hi. My Apps keep crashing on my main Sky Q box. It's happened with all the apps. I have tried refreshing but nothing seems to work? Help!!
Re: Apps keep restarting
Hi @danhollywood Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
