2
This discussion topic has been answered Discussion topic: Apps keep closing down
This message was authored by: Adz182
When have app open like YouTube or Netflix it just keeps turning off
Re: Apps keep closing down
Hi @Adz182
Hi @Adz182
Avatar for Adz182
Thank you
