Discussion topic: Apps disappear with essentials?
This message was authored by: Coxy731
We have moved to essentials and now only have TV guide, this has only just happened as when we first changed we still had apps etc, can anyone advise please. Thanks
Re: Apps disappear with essentials?
Have you tried rebooting your box?
Avatar for Coxy731
Level 0 icon
Yes we have but contacted sky now and they said all the apps go with essentials!! This wasn't the case 2 months ago as they were all there 😞
Strange - must be something new.
@Coxy731 you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
