Discussion topic: Anyone help.?
This message was authored by: MrsLP
Anyone help.?
I tried to record the masked Singer for 6:30 pm tonight and I had a message on screen to say
"you cannot record this program"
I record everything I want to see and watch it when I want to see it.
I have not been cut off and my bills are up-to-date... can anyone help?
Re: Anyone help.?
@MrsLP
I set mine up to record it early in the week and it's still in the Schedule. Perhaps try a reboot of your box…
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
This message was authored by: jd0310
Re: Anyone help.?
I have exactly the same problem. I get the same message as MrsLP :-  'This programme cannot be recorded'. *
It only happens with The Masked Singer.
I tested others, and I am able to record other programmes on other channels, no problem, but The Masked Singer brings up the message above*.
Re: Anyone help.?
@MrsLP @jd0310
Might be worth reporting it to the Viewer Relations Team by email at viewerR@sky.uk
Re: Anyone help.?
Mine recorded fine and has series linked tomorrow's episode into the Schedule.
Re: Anyone help.?
@MrsLP @jd0310
It might be unconnected but the programme time was reduced and started at 6:40 not 6:30. This was due to an act (Red Panda) being edited out of that episode. This was apparently due to sensitivity issues after the recent fatal bar fire in Switzerland.
