Discussion topic: Intermittent failure of signal on tv causing screen to go blank, lose sound, picture fragments. Need
Message posted on 03 Jan 2026 11:49 PM
Loss of signal in tv, complete loss of picture sometimes, picture becomes fragmented. Weather is cold but no snow, wind or rain
Message posted on 04 Jan 2026 02:52 AM
Re: Intermittent failure of signal on tv causing screen to go blank, lose sound, picture fragments.
Any error message showing?
No signal and no satellite signal messages are different…
”No signal” messages tend to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
With a “no satellite signal” message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling
so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 wind and rain can affect the satellite signal and following adverse weather wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
